Интересная инфа | мазда (mazda) форум | 02 авг 2012 14:33
 Заголовок сообщения: Интересная инфа | мазда (mazda) форум
02 авг 2012 14:33
Автомобиль: mazda 626
Рылся в нете и нашел такой вот список з/ч подходяших на форд проб и 626. Может кому пригодиться:
Ford Probe/Mazda 626 & MX-6
ACT Clutches:
Performance Pressure Plate:
88-92, 2.2L, Turbo, (34%), MZ-010, $190.53
88-92, 2.2L, Turbo, (80%), MZ-010X, $277.93
88-92, 2.2L, NA, (34%), MZ-017, $208.01
92-97 2.0L NA, (34%), MZ-018, $204.52
93-97 2.5L V6, (35%), MZ-015, $173.05
Performance Street Disc:
88-92 2.2L Turbo, MZSD069, $121.49
88-97 2.0L NA/2.2L NA/2.5L V6, MZSD056S, $117.99
Solid Racing Disc:
6-Puc Very Aggressive Contact, $99.20
4-Puc Brutal Contact, $82.59
Release Bearing:
83-00, RB091, $32.34
**** Mazda part #'s same as Ford, years are different, call for more info ****
Blitz Boost Controllers:
SBC I-D Boost Controller, 15055, $575.34
Dual Solenoid Boost Controller (Black), 14044, $472.14
Dual Solenoid Boost Controller (Silver), 15044, $489.34
Street Spec Boost Controller, 14045, $290.68
B&M Pro Edge Short Shifter:
93-97, 45078, $148.50
Borla Performance Exhaust System:
93-94 MX6, 14429, $463.20
93-94 Probe GT, 14429, $463.20
95-97 Email for details
Bosal Brospeed Exhaust:
93-95 MX6 & 626 V6, 112-201, $540.65
93-95 MX6 & 626 4Cyl, 112-202, $540.65
93-95 Probe 4cyl, 112-203, $540.65
93-95 Probe V6, 112-207, $540.65
Centerforce Clutches:
Ford Probe:
93-97 2.5L V6, Centerforce I, CF056543, $214.41
Centerforce II, CFT543056, $250.75
Dual Friction, DF543056, $286.72
93-97 2.0L, Centerforce I, CF003900, $199.87
Dual Friction, DF900003, $310.24
90-92 3.0L, Centerforce I, CF361123, $208.96
89-92 2.2L Turbo, Centerforce I, CF361844, $176.93
Centerforce II, CFT361844, $218.04
Dual Friction, DF103884, $362.87
89-92 2.2L, Centerforce I, CF361812, $145.36
Dual Friction, DF111812, $300.69
Mazda MX-6:
92-99 2.5L, Centerforce I, CF056543, $214.41
92-99 2.0L, Centerforce I, CF003900, $199.87
88-91 2.2L, Turbo, Centerforce I, CF300500, $230.31
Centerforce II, CFT500300, $266.65
Dual Friction, DF500300, $304.88
88-91 2.2L, Centerforce I, CF056543, $214.41
Mazda 626:
92-96 2.5L, Centerforce I, CF056543, $214.41
Dual Friction, DF543056, $287.09
92-96 2.0L, Centerforce I, CF003900, $199.87
10/87-92 2.2L, Turbo, Centerforce I, CF300500, $230.31
10/82-9/87 2.0L Turbo, Centerforce I, CF007543, $189.88
Centerforce II, CFT543007, $226.22
Dual Friction, DF543007, $287.09
1/79-9/82 1.9L, Centerforce I, CF233522, $212.66
Dual Friction, DF522233, $285.34
Corbeau Seat Brackets:
93-99,Probe, MX6 Driver Side, D982T, Passenger Side, D983T, $78.50 each
88-92,Probe, MX6 Driver Side, D938T, Passenger Side, D939T, $78.50 each
82, 626, Driver Side, D314T, Passenger Side, D315T, $78.50 each
83-86, 626, Driver Side, D302MAF, Passenger Side, D302MAF, $78.50 each
**** Go to the Manufacturers Tab and see all the Seats in the Corbeau line ****
Eibach Pro-Kit Springs:+
93-97, 5526.140, $213.79
89-92, 4cyl, 5511.140, $213.79
92-97, 5522.140, $213.79
Eibach Alignment Kits:
89-92, Front or Rear, 5.83450K, $31.31
93-97, Front or Rear, 5.83450K, $31.31
Energy Suspension Bushings:
88-92
Front Sway Bar Frame Bushings, 18mm, 9-5122, $14.36
Rear Sway Bar Frame Bushings, 16mm, 11-5107, $6.77
Front End Links, 9-8106, $15.08
79-82
Front End Control Arm Bushing Set, 11-3101, $9.79
Front End Links, 9-8123, $15.08
Fidanza Lightweight Aluminum Flywheel:
88-92 2.2L Probe N/A, 186221, $371.00
88-92 2.2L 626 & MX6 N/A, 161221, $421.25
88-92 2.2L Probe Turbo, 186001, $371.00
88-92 2.2L 626 & MX6 Turbo, 161891, $421.25
93-95 2.5L Probe, 186471, $371.00
90-00 2.5L 626 & 93-97 MX6, 161251, $421.25
Granatelli 255 liter per hour Fuel Pump:
For Probe And Mazda MX6
88-92, all, Model 315/341, $125
93-97, all, Model 317/342, $125
Capable of supporting over 500 HP
Some modification may be required!
GReddy EVO Exhaust System:
93-95 MX6, 10146610, $527.12
GReddy SP Exhaust System:
93-94, Probe GT, (60mm Pipe 120X130mm Tip), 10145500, $572.00
GReddy Turbo Boost Controllers:
Profec A Spec (Fuzzy Logic), 15500203, $523.60
Profec B Spec (Electronic), 15500202, $369.60
Profec B Spec Clear Blue (Electronic), 15500204, $351.12
HKS EVC electronic boost controller:
EVC IV-Si, 4503-RA009, $594.00
Scramble Boost Control Trigger Switch, EVC IV-Si only, $70.40
EVC EZ, 4503-RA008, $347.60
Installation Kits, 88-92 Probe & MX6 turbo, 4503-011US, $17.60
Installation Kits, 86-89 626 GT, 4503-011US, $17.60
HKS Fuel Pump Upgrade:
External Fuel Pump Upgrade Kit, 132psi/65gph, 1408-M01US, $651.20
In-Tank Fuel Pump, 165psi/90gph, 1407-001US, $734.80
Adjustable Fuel Pressure Regulator, 1407-RA105, $189.20
HKS Intercooler Pipe Kit:
88-92 Probe Turbo, 1302-F01US, $400.40
88-92 MX6 Turbo, 1302-Z01US, $365.20
88-89 626 GT, 1302-Z01US, $365.20
HKS Turbo Exhaust System
88-92 Turbo, dual 60mm tip, 60mm piping, LET-Z06, $519.20
HKS Sport Exhaust:
93-95 Probe V6 GT, 106mm tip, 60mm piping, LET-F02, $484.00
HKS Super AFR, AFM/MAF based fuel adjustment
Universal, 4606-RA001, $351.12
HKS PFC F-CON:
86-87 626 GT, 4201-Z004US, $1240.80
Injector Pulse Monitor, 4403-SA001, $400.40
GCC for fine tuning FCON, 4206-RA006, $519.20
HKS Super Mega Flow Intake System:
93-97 Probe V6 GT, 93-96 MX6 V6, 1504-SPFZ05A, $136.40
HKS Turbo Timer V and Harness:
4101-RA009, Type 0, Silver, $85.50
4101-RA010, Type 0, Purple, $85.50 DISCONTINUED!
4101-RA011, Type 1, Silver, $129.95
4101-RA012, Type 1, Purple, $129.95
88-92 turbo, 4103-RZ001, $21.12
HKS SSQV (Super Sequential Blow-Off Valve)
Universal, 1421-SA001, $220.00
Racing Type II, 1421-RA001, $448.80
Weld-On 50mm Steel Flange, 1410-SA001, $39.60
Weld-On 65mm Steel Flange, 1410-SA002, $52.80
Weld-On 60mm Aluminum Flange, 1410-SA003, $30.80
Recirculation Fitting 1" ID, 1421-FIT001, $10.56
Round Insert, Purple Metallic, lower sound pitch, 1422-SA001, $13.20
Fin Insert, Gold, higher sound pitch, 1422-SA002, $13.20
HKS Standard and Racing Bypass Valves
Standard Bypass Valve (engines to 300hp):
Right-Handed, 17670-025100, $66.00
Left-Handed, 17670-024100, $66.00
Racing Bypass Valves:
3.5 - 9 psi (white), 17670-014100, $180.40
6 - 12 psi (yellow), 17670-013100, $180.40
7 - 14 psi (blue), 17670-004100, $180.40
12 - 18 psi (red), 17670-016100, $180.40
Valve Springs, white yellow blue or red, $10.56
Weld-On Flange, 08108-09159, $8.80
Threaded Flange, 17652-001100, $17.60
HKS Twin Power Ignition Amplifiers:
DLI, 4301-SA005, $550.00
Distributor, 4301-SA007, $413.60
HKS Variable Boost Controller:
88-92 Probe & MX6 Turbo, 17265-110US, $105.60
86-87 626 GT, 17265-108US, $118.80
88-89 626 GT, 17265-110US, $105.60
Hotshot Headers:
93-95, Probe GT, Mazda MX6 V6, FM3050, $530.00
Hotshot Intakes:
93-98, Probe GT V6 / MX-6 (5-speed only), FM4050, $205.00
93-98, Probe GT V6 / MX-6 (Automatic), FM4051, $205.00
(NEW! complete CAI now includes: Intake, elbow and filter)
inTrax Lowering Springs:
Probe:
88-92, -1.8"(F), -1.7"®, 30.1.008, $216.75
93-97, V-6, -1.8"(F), -1.7"®, 30.1.009, $216.75
93-97, 4Cyl, -1.8"(F), -1.7"®, 30.1.011, $224.25
626/MX6:
88-92, -1.7"(F), -1.6"®, 45.1.005, $216.75
93-97, V-6, -1.7"(F & R), 45.1.006, 216.75
93-97, 4Cyl, -1.7"(F & R), 45.1.009, $216.75
626:
-88, Sedan 4Cyl, -1.7"(F), -1.6"®, 45.1.020, $224.25
98+ Sedan, 6Cyl, -1.7"(F), -1.6"®, 45.1.014, $209.75
98+ Sedan, 4Cyl, -1.6"(F & R), 45.1.017, $224.25
K&N Filtercharger Air Filter:
93-97, 33-2049, $37.14
89-92, 33-2026, $38.47
1990 , 33-2024, $37.08
86-87, 33-2050, $37.16
79-85, E-2790, $34.87
K&N Filtercharger Injection Performance Kit (50-State Legal) :
93-97, 57-2507, $128.50
KVR Performance Carbon Fiber Semi-Metallic Brake Pads:
Probe
94-97, Front, M7515, $63.13 set
1993 , Front, M7463, $59.32 set
89-92, Front, M7288, $50.96 set
93-97, Rear, M7464, $55.52 set
89-92, Rear, M7289, $47.92 set
KVR Performance Cross-Drilled or Slotted Brake Rotors:
93-97, Front, MA850, $84.60 ea.
93-97, Rear, MA851, $79.20 ea.
89-92, Front, MA833, $69.30 ea.
89-92, Rear, MA835, $86.40 ea.
KYB GR-2 Gas Struts & Shocks:
89-92 Probe, MX-6, and 626
Front, 235046/7, $56.36 ea.
Rear, 235048, $56.36 ea.
93-97 Probe/MX-6
93-99 626:
Front, 235601/2, $61.61 ea.
Rear, 235603, $65.45 ea.
KYB Strut Mounts & Bearings (Manual Trans. Only):
Front Strut Mount, SM5041, $46.84 each
Front Strut Mount Bearing, SM5127, $21.87 each
Rear Strut Mount, SM5035, $46.34 each
93-97 Probe/MX-6
93-99 626:
Front Strut Mount, SM5076, $27.97 each
Front Strut Mount Bearing, SM5129, $17.49 each
Rear Strut Mount, SM5093/4, $72.90 each
KYB Strut Boots:
89+ Probe, MX-6, and 626, SB101, $11.53 each
Magnecor KV85 Competition Spark Plug Wires:
93-97 2.5L, 65129, $167.70
93-97 2.2L, 45245, $84.71
90-94 3.0L, 6533, $77.06
88-92 2.2L Turbo, 4527, $50.29
88-92 2.2L N/A, 45105, $46.32
79-87 626, 4503, $47.02
NGK Iridium Plugs: (min 4 plugs)
90-91, Turbo, 6441, $6.40 each
90-92, N/A, 6441, $6.40 each
93-94, 2.0L, MT, 5464, $6.40 each
93-97, 2.5L, 2477, $6.40 each
95-97, 2.0L, 5464, $6.40 each
98-01, 2.0L, 5464, $6.40 each
PaceSetter Monza Exhaust System:
93-97 Probe 2.0L, 88-1404, $200.16
93-97 Probe 2.5L, 88-1403, $232.34
93-97 MX6 2.5L, 88-1482, $232.34
90-92 Probe 3.0L, 88-1400, $189.44
89-92 Probe/MX6 2.2L, 88-1328, $214.46
PaceSetter Armor Coat Header:
93-97 Probe/ 93-95 MX6 2.5L, 72C1161, $321.71
89-92 Probe 2.2L NA, 72C1060, $253.79
PaceSetter Black Paint Header:
93-97 Probe/ 93-95 MX6 2.5L, 70-1161, $214.46
89-92 Probe 2.2L NA, 70-1060, $164.41
PaceSetter Air F/X Intake System:
*** Discontinued ***
PaceSetter Quik-Shift Adjustable Throw Shifters:
93-97 Probe/MX6 GT, 01-0622, $71.46
88-92 Probe/MX6 GT/626, 01-0620, $71.46
Perma-Cool Engine Oil & Transmission Cooling Products:
Universal Engine Oil Cooler Kits:
150 HP 3/4"x7-1/2"x12-1/2" Remote Style, 69195, $92.12
150 HP 3/4"x7-1/2"x12-1/2" Sandwich Style, 69189, $85.44
250 HP 1-1/2"x7"x14", Remote Style, 10195, $110.62
250 HP 1-1/2"x7"x14", Sandwich Style, 10189, $104.10
450 HP 1-1/2"x7"x21", Remote Style, 40195, $181.64
450 HP 1-1/2"x7"x21", Sandwich Style, 40189, $187.38
Oil Cooler Kit Accessories:
Trans Remote Mount Kit, 102, $7.73
Metal Mounting Kit, 103, $3.98
Nylon Tie Mounting Kit, 105, $3.75
Temp Gauge Kit, 15106, $53.50
Oil Filter Relocation Kits:
Single Oil Filter, 10695, $47.32
Dual Oil Filter, 10795, $62.59
Automatic Trans Filter Kits:
Standard Kit w/Filter 10678, $38.90
Deluxe Kit w/Filter & Gauge 10677, $79.31
Turbo Flex High Performance Electric Fans: (Reversible Push/Pull)
10" Fan, Mounting Area 13"x10-1/2"x2-1/2", 19010, $92.84
12" Fan, Mounting Area 12-1/2"x12-1/2"x3-3/4", 19008, $105.18
14" Fan, Mounting Area 14"x14"x3-3/4", 19114, $120.79
16" Fan, Mounting Area 16"x16"x3-3/4", 19115, $127.15
18" Fan, Mounting Area 17-3/4"x17-3/4"x3-3/4", 19117, $140.23
Turbo Flex Electric Fan Accessories:
Wiring Kit w/170 Degree Thermal Switch, 19001, $19.56
Electric Fan Wiring Kit, Adjustable (Probe), 18905, $55.08
Metal Mounting Kit, 104, $4.06
30 Amp A/C Relay, 19002, $8.33
Razo Pedals (3 piece sets for Manual Transmission):
Carbon Black
Small, RP55, $53.27 (Retail $73.99)
Large, RP54, $54.71 (Retail $75.99)
Aluminum w/Chrome Plate
RP47, $41.03 (Retail $56.99)
Magnesium Alloy
Small, RM35, $55.43 (Retail $76.99)
Large, RM34, $56.15 (Retail $77.99)
Suspension Techniques Sport Lowering Spring Set (-1.0"):
93-97 Probe/MX-6, 60310, $190.37
88-92 Probe/MX-6, 60305, $190.37
Techna-Fit Coated Stainless Steel Brake Lines:
93-97, FORD-1010, $103.50
88-92, FORD-1000, $103.50
Available in red, yellow, blue, and clear
Tokico Performance Struts:
93-97, Front, HB3081, $101.06
HB3082, $101.06
Rear, HB3083, $98.25 (X2)
89-92, Front, HB3031, $95.44
HB3032, $95.44
Rear, HB3066, $98.25
Tokico Illumina Adjustable Struts:
93-97, Front, BB3081, $144.58
BB3082, $144.58
Rear, BB3083, $144.58
Tokico Advanced Handling Lowering Springs:
93-97 Probe/MX6 V6, -1.0", HPS5038, $188.84
93-97 626 V6, -1.5", HPS5057, $188.84
Tokico Advanced Handling Suspension Kits:
93-97 Probe/MX6 V6, -1.0", HPK229, $504.09
93-97 626 V6, HPK227, -1.5", $504.09
Tokico Illumina Advanced Handling Suspension Kits:
93-97 Probe/MX6 V6, -1.0", ILK214, $652.07
93-97 626 V6, -1.5", ILK226, $652.07
Unorthodox Ultra Light Weight Flywheel:
060810600, $565.00
Unorthdox Racing Ultra S- Lightened Underdrive Crank Pulley:
93-97, 2.5L DOHC 24V, 0208006xx, $194.65
(xx: 01- Black, 02- Clear, 03- Red, 04- Blue)
626, 98-00, 2.5L DOHC 24V, 0208009xx, 194.65
Probe, 88-92, 2.2L SOHC 12V, 0208105xx, $177.65
93-95, 2.0L DOHC 16V, 0208110xx, $177.65
Комментарий к файлу: рычаг от ситроена к примеру может решить проблему с шаровой на 626 т.к. она на болтах
8888.jpg [ 33.38 | Просмотров: 1956 ]
mazda 626 GE 2.5 хетч kl-ZE 1994 г.
 Заголовок сообщения: Re: Интересная инфа | мазда (mazda) форум
03 авг 2012 07:10
Автомобиль: 626 ge fs
рычаг от ситроена...это что-то новенькое))
GE 626 2.0 16V FS sedan92г.
03 авг 2012 07:24
Ну уж очень похож :D тока крепежа под косточку нет.
