вопросы по прочитанной теме
1. Disconnect engine control module (ECM) multi-plug.
2. Connect breakout box between ECM and harness multi-plug.
3. Ensure throttle valve is closed.
4. Switch ignition ON.
5. Ensure battery voltage above 11,5 volts.
6. Check voltage between ECM multi-plug terminal and earth Fig. 11 .
7. If voltage not as specified: Slacken TP sensor screws.
имеется ввиду в закрытом состоянии..
8. Turn TP sensor until voltage is as specified Fig. 12 .
9. Tighten TP sensor screws.
10. Verify adjustment as follows:
11. Check voltage between ECM multi-plug terminal and earth.
12. Fully open throttle.
13. Check voltage between ECM multi-plug terminal and earth.
14. If voltage not as specified: Suspect faulty TP sensor.
Throttle closed: 0,4-0,6 V
Throttle fully open: 3,5-5,2 V
а как открыть или закрыть его?
