схема подключения выносной катушки и (или) коммутатора | мазда (mazda) форум | 26 фев 2009 13:11
 Заголовок сообщения: схема подключения выносной катушки и (или) коммутатора | мазда (mazda) форум
26 фев 2009 13:11
Как то было дело искал я эту тему и потратил довольно много времени, а тут она на глаза попалась. Пусть чтоль у нас тут тоже будет, может понадобится кому ;)
Установка\замена\ремонт\подключение внешнего\выносного коммутатора или катушки вместо встроенных в трамблер. Схема.
For Informations Sake, below is a list of the MX-3 Distributor plug wire colors & their functionality:
6-pin Plug (from the top to bottom)
Solid Orange (Ignition control module ecu trigger)
Black w/green stripe
Pink w/white stripe (camshaft position sensor SGC signal)
Pink w/green stripe (camshaft position sensor SGT signal)
White w/red stripe
Black w/light-green stripe (ECU constant ground)
3-ping Plug (fromp top to bottom):
Solid Blue (ignition coil +)
Yellow w/blue stripe (tachometer signal from ignition coil)
Solid Red (ignition coil -)
Выносной коммутатор
3 (Explained): To hook up the HEI module so it functions properly you will need four wires, each with a female disconnect on one end and one with a ring terminal on the other end and the other 3 with the self-tapping terminals.
The wire with the ring terminal is used on pin "W" on the HEI module and is grounded to the chassis of the car
One of the three other wires is routed to the top (solid orange) 3-pin Plug from the distributor and connects to pin "B" on the HEI module
The 2nd of the three other wires connects to the bottom (solid red) wire on the 3-pin Plug from the distributor and connects to pin "C" on the HEI module
The last wire MUST BE at least 16-guage and connects to the top wire on the 6-pin distributor plug (solid orange) and connects to pin "G" on the HEI module.
внешняя катушка и коммутатор
(Explained): To hook up the HEI module so it functions properly you will need seven wires total.
1: One of the wires with a ring terminal is used on pin "W" on the HEI module and is grounded to the chassis of the car
2: Another wire goes from the "G" terminal on the HEI module to a self-tapping terminal on the orange wire (top wire on the 6-pin distributor plug). This wire MUST be at lesat 16-gauge or the HEI module may get extremely hot and/or the wire will melt due to the 5-amp current this wire requires.
Wires 3-6 can be connected two ways, you can either run all of the wires off of the "B" and "C" terminals from the HEI module OR (as shown in my diagram) run all of the wires off of the "+" and "-" inputs from the external ignition coil.
3: The next wire depends on which way you run your wires. This wire needs to go from the ignition coil's "+" to the HEI "B" pin.
4: Another wire needs to go from the coil's + pin (OR hei "B" pin) to the top wire on the 3-pin distributor plug wire (solid blue).
5: Now you need a wire going from the "-" input on the external coil to the HEI "C" pin.
6: Then, you need a wire from the coil's - pin (OR hei "C" pin) to be routed to the 3-pin distributor plug's bottom wire (solid red).
7: Lastly, you'll need to rig the tachometer to work. In order to do this, use a self-tapping terminal on the #6 wire you just hooked up. Cut this new wire in half and shove a 1000-ohm resistor (1/2 Watt) inside of it. I TIGHTLY wrapped electrical tape over the resistor and two-wires that the resitor is shoved in so it won't fall out. If you do it this way, use wire loom to cover the electrical tape and sheild it from too much heat. (see picture to right to see how I did mine)
NOTE: USE A RESISTOR for the tach signal, if you do not, you will burn out your tachometer in no time. The stock ignition coil has a 1k-ohm resistor built in for this purpose.
крышка
общий вид
Изображение[/
зы а еще транзистор там говорят стоит (?) меняют на BU-941
ззы тут еще по данной теме есть
Оригинал находится тут
 Заголовок сообщения: Re: схема подключения выносной катушки и (или) коммутатора | мазда (mazda) форум
02 мар 2009 14:54
мне под новый год нужна была у меня катушка на корпус пробила, так я тоже мучался но со второго раза заклеили и пока тьфу-тьфу но я нашел еще и по лицензии катушки делают да и коммутатор в ней поменять тоже можно
xedos 9 2.0 KF
03 мар 2009 12:08
Во всей вышеописанной конструкции тяжело найти фаер тауэр (красный шпынек, который вплавлен в катушку). Можно конечно крышку купить с семью сосками и не заморачиватся, но она стоит 1500р новая.
03 мар 2009 12:29
отпилить от жыгулевского трамблера :)
31 мар 2009 09:50
а вот тут есть принципиальная схема трамблера. Распиновка может отличаться в каждом конкретном случае и это нужно отдельно мерить, но смысл остается
оригинал темы тут
Спасибо pennkill'у(ремонт трамблера КЛ)
02 сен 2009 17:21
ну и сюда еще ссылку на ремонт коммутатора для кучи
http://www.mx3-club.ru/forum/viewtopic.php?f=10&t=3649
03 сен 2009 14:24
RespecterX9 это не ремонт, это как сделать его полный аналог )
03 сен 2009 20:27
Аналог... ремонт... ИМХО моё такое:
это именно ремонт узла как такового, т.к. _полный_ аналог означает использование оригинальных компонентов и схемотехники.
А в данном случае, и во многих других в том числе, это всего лишь свой повтор того, что было сделано производителем.
Как бы это ни было исполнено, но факт что нужна функциональность, примерно аналогичная стоковому варианту, но дешевле в исполнении.
По всем видимым мной схемам функционал соблюдён, но со своей элементной базой. Это не аналог, это похожие схемы с похожим результатом.
Но согласен, что работает примерно одинаково (кстати по-поводу тонкостей это вопрос! пофиг пока не вылезет), т.е двигатель работать с таким колхозом однозначно будет. И скорее всего будет работать нормально. Но варианты возможны....
зы если тебе хочется и нравится на каждый мой пост возражать просто так, то приходи в личку, чтобы не флудить и не засорять и так зас__нную конфу :)
07 апр 2010 23:51
Автомобиль: Mazda 626 1992год 2.5V 6 KL
Подскажите, пожалуйста, а какую катушку поставить, вместо родной???
Mazda 626 2.5 v6 KL
08 апр 2010 08:25
Баллы репутации: 52
я поставил от 626ГФ (которая без трамблерная) 1 катушку от туда взял.
MAZDA 626 FS-ZE - было
MAZDA 6 - владею
08 апр 2010 12:13
там можно ставить лицензию по мобилитрону и не хрена не выносить а номер по каталогу jc K73010 в украине они у нас в городе есть
xedos 9 2.0 KF
09 апр 2010 20:25
А сколько она стоить, у вас в Днепре??? Я поставил от ВАЗ 2108 , работает, но после прогазовки, в глушитель стреляет, это может быть из-за катушки???
Mazda 626 2.5 v6 KL
10 апр 2010 07:07
Баллы репутации: 52
нет ! это форсы или УОЗ. ну скорее форсы льют... чистить надо.
MAZDA 6 - владею
10 апр 2010 20:29
Спасибо большое, будем разбираться!!!
Mazda 626 2.5 v6 KL
24 апр 2010 16:26
Кстати номер катушки на 2.5 kl CF-21, это катушка mobiletron стоит 1500руб, себе недавно поставил.
24 апр 2010 18:14
Интересно, как стала и как работа всего девайса в целом? Очень хорошо, что фирма сподобилась выпускать катушки - это основная болезнь трамблёров KL. А трамблёр в сборе б/у, тоже не самое бюджетное решение, да и не самое надёжное тоже
27 апр 2010 16:17
Она один в один как и старая(которая стояла) даже маркировка совпадает
DSCN3268_hf.jpg [ 185.04 | Просмотров: 42778 ]
DSCN3270_hf.jpg [ 168.1 | Просмотров: 42778 ]
DSCN3271_hf.jpg [ 192.92 | Просмотров: 42778 ]
28 июн 2010 21:45
Всем привет.
Поправьте ,если я не прав -предположим Кседос 9 2,5двиг. и 2,0 двиг. это разные движки ,но трамблёр у них одинаковый,катушки должно быть тоже одинаковые?? выходит можете достоверно сказать какое сопротивление первички и вторички на катушке ? А то моя приказала "долго жить" - разница в десятки кОм , во всяком случае мне так сказали в ремонте.Точную цифру сказать не могут ,а попадать на бабосы не хочется вот так глупо,хоть было б чем апелировать.
Дело в том что ребята сами не знают точных данных ,а просто померяли у MX-6 2,5л. с новой катушки ,но там трамблёр другой чем в моей ,они утверждают что катушки одинаковые.Там трамблёр с маркировкой KL 01 ***** ,а у меня KF 34 *****
все в ступоре - но я больше.
спасибо.
Xedos 9 1995 2.0 ручная
29 июн 2010 10:39
одинаковые катушки
06 июл 2010 02:18
Баллы репутации: 40
RespecterX9
ыт, дядь, а как кричал - нинада так делать. штатное - наше фсе :D
323F BA KL-ZE 2.5 V6 94г
Per rectum ad astra!
06 июл 2010 06:40
Баллы репутации: 52
так если катушка одинаковая ...соответственно она будет штатной
MAZDA 6 - владею
28 июл 2010 02:08
Автомобиль: mazda Millenia, 1995г.,2,5V6
CiretPro
Подскажите пожалуйста, у меня похожие признаки, на нейтралке двиг крутиться, а при езде обороты не набирает, провалы, сама сбрасывает обороты где то с 3-ёх тыс до 1тыс и т.д., не тянет вообще. Может то-же трамблёр, замена свечей даёт эффект на час потом по новой, нагар при осмотре в норме. Заранее сп.
МаздаФан)
13 янв 2011 03:33
Автомобиль: mazda 626
[quote="Nikotin"]CiretPro
Nikotin подскажи пожалуйста у меня на 626 GE 2.0 FS такая ж проблемка возникла .ты уже нашол причину., что может быть за поломка?
13 янв 2011 06:50
Баллы репутации: 52
pioner писал(а):
Nikotin писал(а):
CiretPro
тут почитай viewtopic.php?f=11&t=27097
MAZDA 6 - владею
02 мар 2011 01:34
Баллы репутации: 57
RespecterX9
добавлю картинку покрасифше :D
Mazda MX3 KLZE HEI Mod Wiring Diagram.jpg [ 89.58 | Просмотров: 40037 ]
MX-3,КLZE,Blaze Red
